show mvrp ports counters
show mvrp ports {port_list} counters {event | packet}
Description
Shows the port MVRP statistics. The statistics for packet or event counters are displayed as per input.
Syntax Description
mvrp Multiple VLAN Registration Protocol.
ports Ports.
port_list List of ports in the switch separated by a comma or "-".
counters MVRP packet and attribute event counters.
event MVRP attribute event counters.
packet MVRP packet counters (default).
Default
Packet counters.
Usage Guidelines
This command is to show the port MVRP statistics. The statistics for packet or event counters will be displayed as per input. The default is packet counters. The packet counters include Number of VLANs registered on the port, Number of Failed Registrations, Number of MVRPDUs received, Number of MVRPDUs sent, Number of erroneous MVRPDUs received, and the source address of the MVRP message last received by the port. The event counters include the number of different events received/transmitted.
# show mvrp ports 9,11,13 counters packet
Port    VLANs    Failed    Rx Pkt  Rx Error   Tx Pkt     Last Source
        Regs     Regs      Count   Count      Count      Address
    9      2          0         0         0        64   00:00:00:00:00:00
    11     2          0    806836         0    433754   00:22:97:00:41:e7
    13     2          0    784176         0    404794   00:22:97:00:41:e8
Regs: Registrations
# show mvrp ports 9 counters event
Port :  17
    MRP Attribute Events       Rx          Tx
  In                              250          56
  JoinIn                            0           0
  JoinMt                          224         386
  LeaveAll                          5           0
  Lv                                0           0
  Mt                                0         152
  New
In       : Not declared, but registered
JoinIn   : Declared and Registered
JoinMt   : Declared, but not registered
LeaveAll : All registrations will shortly be deregistered
Lv       : Previously registered, but now withdrawn
Mt       : Not declared, and not registered
New      : Newly declared, and possibly not previously registered
This command was first available in ExtremeXOS 15.3.
Platform Availability
